ZazaCast
Major Contributor
I have done one of these Ingus based sliders but it's quite hard to slide the carriage. It seems too much friction. Has anybody found the same problem and a solution? I tried using a silicone spray but it doesn't really help.
I found that if you loosen the allen bolts that hold the bearing cages to the carriage...slide the carriage onto the rail...it self-aligns. Then you can tighten the allen bolts (while it's on the rails) & it should slide just fine.
If one of those bearing cages is just a little 'off', it will be tough to slide.
Try it and let me know how you make out.:thumbup:
