8 Mbps is fine.
I don't understand the looping problem -- need more detail.
Several have asked why a higher or lower bit rate...?
I always assumed the obvious --
1. video quality
2. file size
Is it not that simple? The higher the bit rate, the higher the video quality. Though I can't believe a regular DVD player would have problems player and higher/lower bit rate. What a gyp!
When rendering with Vegas and the HMC150 as mpeg2, my file output was a m2t file, not a mpeg2 file! Did I do something wrong?
Kurious...i know, but i have had problems with my Panasonic mid-priced dvd player at anything higher than 8Mbs...not sure if there is a general rule of thumb, so i always render for dvd at 8mbs, regardless of how static or motion-intensive my footage is....if someone can tell me otherwise, please do...i get a lot of conflicting info about this. Thanks!
http://www.vimeo.com/chrislight
...but then, i got to a point, and i think some people are in denial about this...no matter how good your footage looks, it will only look so good on DVD....if your footage is shot in HD, edited in HD, then all you've been looking at is HD...your eye gets so used to HD that a dvd, no matter how high the bitrate or quality encode, you're now subjected to SD, albeit NICE SD...but definately not so pleasing to the eye when you've been staring at HD for weeks.
just a thought
Shouldn't affect anything. .m2t is MPEG-2.
Do you mean you use 8 Mbps at a constant bitrate? Not necessary. You're just wasting space.
