J Davis
I'm on an editing project where I'm getting .mts media from HF10, HF11
and media is shot at 24 fps (embedded in 60i).
Am using FCS2, version for fcp is 6.0.5, and an intel mac.
I've done many searches and have found the following post designed for
HV30 capture of 1080i60 which describes reverse telecine to 1080p24
post is here --> http://support.apple.com/kb/HT2410
The problem is that with AVCHD we have to use log and transfer,
not log and capture and we end up with a file that is prores 29.97 interlaced
instead of 60i which is what the camera embeds in.
So far I'm using the same compressor settings from the apple post above
in the hope that it works even though this source media is not 60i.
It seems to be working as far as I can tell.
To check the transcodes I'm stepping through the frames
one at a time looking for pulldown (repeated frames or interlacing).
The first and last frames have the jaggies but all others seem to be fine.
I know that these AVCHD files do not have duplicate frames flagged for
removal. Does compressors' reverse telecine option contain frame matching
to see if they are identical?
Thoughts anyone?
Of note :- Isaac Brody has an interesting post about this same topic where he
mentions a cinetools workflow and JES Deinterlacer
his post is here
--> http://dvxuser.com/V6/showpost.php?p=1505159&postcount=18
Isaac, if your reading this can you share some of your expert knowledge
on cinetools and JES?
Thoughts anyone?
his post is here
