Bassman2003
Hello,
I have been in contact with a Panasonic tech about turning spanned clips into one clip because I am losing some frames at clip span points. This is due to my Editor (Edius) not getting the GOP structure.
The tech gave me a DOS workaround which turns all selected clips into one clip. Perfect, but it is in DOS and very clumsy.
Does anybody here know how to write a little Windows utility so it would be easier to select files and folders to join clips?
Here is the code:
<Procedure to merge files>
1. Copy all divided files in a specific folder on the NTFS drive(ex.
C:\AVCHD Temp)
2. If the divided files are 1000.mts, 1001.mts and 1002.mts, Run
"copy /b 1000.mts+1001.mts+1002.mts AVCHDfile.mts" via [Command Prompt].
3. Then divided files are merged into a single file (AVCHDfile.mts in
the example).
Thanks and hopefully a little utility can be created.
Here is the code:
C:\AVCHD Temp)
the example).
