LuckyStudio 13
The Tapeless One
$6000 + add your own Letus 35mm Adapter For Your Reference: (Letus Ultimate is $4500, Letus Elite is $ 1900 & Letus Extreme is $1200).
12 lens group version of the Letus35 Relay Lens Module for B4 mount cameras. 103mm in length. 3/4 stop brighter than the P+S PRO35 relay. This relay lens will allow you to attach a Letus35 Extreme, Elite, or Ultimate adapter directly to the camera body bypassing the stock lens entirely. Precision calibrated to the Letus35 adapters. We cannot guarantee compatibility with other adapters.
When coupled with the Letus35 Ultimate, it is the best 35mm DoF adapter solution, period.
$3500 + Add your own Letus 35mm Adapter.
9 lens group version of the Letus35 Relay Lens Module for B4 mount cameras. 50mm in length. 1/4 stop brighter than the P+S PRO35 relay. This relay lens will allow you to attach a Letus35 adapter directly to the camera body bypassing the stock lens entirely. Precision calibrated to the Letus35 adapters. We cannot guarantee compatibility with other adapters.
Academy frame size
9 lens elements
Razor sharp center and edges
Iris ring
Back focus ring with lock down
Stainless steel flange
f1.8
Academy frame size
9 lens elements
Iris ring
f1.8
