Tim Joy
the plugin checks that the output is 1280x720 and does nothing if it isn't. in preview mode it is, since everything is rendered as square pixels. you can try modifying the script. it's easier than you think. just replace all 1280's with 960's and 640's with 480's. or use a square pixel codec, although i guess there are none that are realtime in 4.5...
btw why rt safe? unlimited is better if you're fine with a frame drop or two.
/matt
So, what I gather is that DVCPRO HD 720p is not a square pixel codec? There are no other options? Time to see about upgrading, although that's bound to open other cans of worms.
I'm fine with changing the script code if I need to, but are you saying that it won't work when it comes time to render for output/ make a master?
I was using RT safe as an example. I usually use unlimited.
