We have both.
What tests does anyone want run?
And I don't do charts.
We have both.
Hi All,
If the HMC-150 has the same "front-end" as the 170, I would assume that, at some point, it has access to a broader color space before a 4:2:0 image is recorded, and I was wondering if the HMC 150 HDMI port can output uncompressed, 4:2:2 ? If this is possible, it would seem like it might be possible to output the same image from the HMC-150 HDMI as is possible from the 170 HD-SDI?
And if the HDMI port outputs this uncompressed 4:2:2, are there HDMI recorders (with large hard disks) that could capture this (assuming these recorders are "somewhat" portable) ?
I'm new to this technology, so please forgive any ignorance or bonehead questions
Thanks!!
Randy
Yes, theoretically the HDMI output should be comparable (if not identical) to the HPX170's HD-SDI output. And yes there are or will be HDMI recorders; isn't the NanoFlash an HDMI recorder? You can output to a blackmagic intensity card through HDMI too.
Nano Flash Recorder
http://www.convergent-design.com/downloads/nanoFlash/nanoFlash Brochure.pdf
Blackmagic HDMI to SDI
http://www.blackmagic-design.com/products/miniconverters/
So it sounds like you can record the output from the HMC-150 HDMI port, but you need TWO devices - an HDMI-->HD-SDI converter box, then you pick up an HD-SDI recorder like the nanoflash (records to SDHC cards).
Hope someone from Panasonic will consider making a recorder with an HDMI port onboard so we could have a "one box" solution for this...
Thanks,
Randy
I'm pretty sure you can record to your hard drive using Premiere Pro if your computer / laptop has an SDI port.
So I'm thinking HDMI-->HD-SDI-->NLE.
Again I have not done this myself but I'm almost 100% sure that it is an option.
http://livedocs.adobe.com/en_US/Pre...t=WS900278C5-C826-45dd-97B5-2AC27D6CC3CB.html
