Green Hornet
Just curious as to the size of the footage of the 150?
Is this anamorphic or square pixels?
Square pixels, full raster. 1920x1080 and 1280x720. The progressive footage of 1080p is stored as full progressive with no pulldown and no interlace artifacts. It's pretty much the ideal storage system for working with computers.
The 150's footage is quite competitive with the 170's in most cases. It's 4:2:0 instead of 4:2:2, and long-GOP instead of intraframe. The 720p looks as good or better on the 150 than it does on the 170 in most instances; the 1080 looks better on the 170.
The workflow and integrated P2 establishment, the VFR, the SD recording, the HD-SDI and firewire streaming, those are all reasons to go with the 170 instead of the 150. If you don't need those things, the 150 is pretty compelling, especially considering the price advantage and the media costs.
The only place where a 150 could prove problematical, footage-wise, is if you're shooting something that exceeds the long-GOP codec's ability to handle. Usually that will mean something with smoke/fire/flashes/sparkling/fog/rippling water, but frankly I wasn't able to break the 150's codec in the brief testing I had with it so that might not even be much of an issue (especially in the PH recording mode).
One last quetion.....
Does it have 2 sd card slots to record to or just one?
b) deliver comparable results at a much lower bitrate. Sony says that 9 megabits of AVC-HD is equivalent to 25 megabits of HDV.
