So, I've been doing a lot of research and I think the HMC150 is for me. I mostly work on short films and some independent features. The productions I've worked on have used lots of random cameras... whether its some weird off the wall camera rigged up to be good enough, an HVX200, or the RED One... I've been on productions across the whole range. I also will probably try to pick up a few more event videographer gigs, maybe even a wedding or two... and also try to branch out into some more commercial work. You know, something to help make ends meet. Part of the motivation for going ahead and buying my own camera is to help my DP, so he can rent it out for me while he's working on other productions. I'm hoping to get $150 to $250/day rented out of my shooting package to help recoup some of the costs. That being said, I'm looking for links to reputable dealers with good prices for these items...
1) Obviously, the HMC-150. Looks like it should be easy to get $3400ish.
2) An extra battery. It looks like I can get the Panasonic 5800mA battery for $180ish. I couldn't find any generics at this point in the game. I think I can get by with one extra battery at this point.
3) An extra memory card. I think it comes with an 8gb, and I want at least one more. Panasonic's cards seem really expensive. I think I can get one of SanDisk's Extreme III 16gb class 6 SDHC cards for about $130. I think thats probably my best option for memory? I own a Transcend 16gb class 6 SDHC that I use for my Asus EEE. I spotted one sitting in someone's picture... do you think that is sufficient? They're only $30 for a 16gb card! I should probably pick up 2 16gb cards total.
4) Tripod. I looked at the Bogen 501HDV. Looks to be about $500, but I think it may be more than I need. I also have considered the Libec TH-M20 which is around $180... I think it may good enough? Tripods are where I'm most conflicted at this point. What are you guys using? What do you think is a good value?
5) Camera case. Should I go soft or hard? Hard seems to have better protection, but soft can accomodate a little more flexibility about bringing different pieces of gear. I considered a soft Kata case for $100. This is another area where I'm really looking for which one you guys have or what you recommend as a good value.
6) A 72mm UV filter, seems to be $20 to $40
I don't think there is anything else I need... I think I'm going to buy a cheap monitor and some extra wiring in a couple weeks at Thanksgiving... probably just going to buy a top end PC monitor to use. I'll modify a mount for a C-stand for it... but I think thats my full list. I think I have a compatible mic and audio equipment I have access to from a colleague. If I sent out the package with my DP, would they be expecting mics? Depending on how everything goes, I will probably end up getting a 35mm adapter in about 3 months as a lot of the work is narrative. I'm trying to think of any other random things I need to buy :huh:
So, where would you buy these things? And what would you be buying? I saw some shooter's kits available but they didn't seem to cover my needs. Any retailers who would put together a good package deal, maybe give me a discount if I purchase everything at once? Thanks for any help!
I found these 2 threads which have some information... posting links for reference! Hopefully we can consolidate a basic package to this thread.
http://www.dvxuser.com/V6/showthread.php?t=149761
http://www.dvxuser.com/V6/showthread.php?t=149372
:dankk2:
-Da3vid-
:dankk2:
-Da3vid-
