I recently purchased a NAXA model NX-550 portable HD LCD TV. If you are looking for a small, 12 volt powered HD utility monitor, this is very very nice. I could not find it on NAXA's site, but, I contacted the company because the box and manual did not mention if it was even HD or not. (I found it at a Pilot Store Truck Stop)
After several days, I got a return call, the salesperson was extremely pleaseant. He assured me it would produce 1080i and 720p images. It is small, about the size of a hi-end panasonic broadcast LCD field monitor. Weighs 6lbs, has a carrying handle and also has an On Board DVD player. NAXA says they are targeting the Trucker market with this model. It is mid sized and easy to put inside a Semi Sleeper cab.
It was 279 dollars and has the following
13.5 inch viewscreen
16x10 aspect (yes, it will stretch the screen a pinch)
ATSC and NTSC tuner
AC/DC powered
Built in DVD Player
HDMI input
PC input
Component Input
Composite input
SVHS Input
RCA Audio In
1/8th inch mini jack Audio In
NAXA does not list this on their site. The specs in the manual says it only does 1280x760 and says NOTHING about HD. The manual is not correct, in fact it offers a lot more than this!! Read On
The monitor definetly does do both 720 and 1080i, no problem.
I plugged my PC into it and it started displaying 1680x1050 Video!!!! That is waaayy beyond what they say it will do and alot more than my Consumer 32 inch HD LCD TV will do VIA the PC input.
It does NOT do 1080p very well, it seems a little jerky. Maybe it is trying to de-interlace it??
The picture is sharp, clear, fairly bright and seems to offer fairly true color reproduction. I have not put my letus on it yet to see if I can use it for focusing a 35mm adapter. But, using it to focus the lens on an HVX200 is a snap!! Im willing to bet I can use it for focusing a 35mm adapter.
I dont know what display panel this thing has in it, but the manufacturer is WAAYY off. It does alot more than what they state it will.
The built in DVD player is also a pretty nice little feature for trade shows or client proof sessions.
I am going out to buy 2 more. This thing is very very nice for the money. If you want a 13 inch display for utility use, or to use for the rigors of every day run and gun shooting. This might be something to look into. I would compare it to my ToteVision HD monitor in quality. Maybe a little less.
Type in NAXA on Ebay to find one. Again it is model number NX-550. I found this one at a Pilot Truck Stop. They are on sale at the time of this post. I have not found any other monitor in the 13 inch size, that is under 3 grand, all of THOSE are of broadcast/Reference grade. I would not go as far as to say this is Broadcast Grade, but, whatever they put in this thing, certainly is allot more than what it specs out at in the manual.
PM me if you want more info.
David Walker
mail@mediamagicproductions.com
ATSC and NTSC tuner
AC/DC powered
Built in DVD Player
HDMI input
PC input
Component Input
Composite input
SVHS Input
RCA Audio In
David Walker
