XL2 Presets for a film look
avery
Does anyone know any good presets for a quality film look from the XL2...please let me know asap...thanks.
Hi Avery,
Here are my presets. They are tweaked for film look, and I use them with very little post production to get an amazing images:
(from previous post)
Here are the reasons for doing as little in Post as possible:
1. Images in DV and HDV lose substantial color detail and fixing/tweaking in Post means that you have little to work with - give it a try - you'll do lots of crying in your sleep. Color correct at the lens/WB, before you hit the DV codec.
2. Post is great if you have a big budget, but everything you can fix in production will save many hours and cost in Post. And you will actually see what it is going to look like - important for lighting setup and visualization.
After my last film, I have spent many hours tweaking and testing. You can get the most stunning images from an XL2 if you do the following:
1. Color balance your shots properly. I use my own warming cards that goes with my Post/Grading procedures.
2. Setup a custom preset as below.
3. Light it well (and meter correctly).
CUSTOM PRESET VALUES:
Gamma: Cine
Knee: Low
Black: Press (I know you lose detail - do it anyway - you will see the results)
Color Matrix: Cine
Color Gain: None
Color Phase: None
R Gain: None
G Gain: None
B Gain: None
V Detail: Normal
Sharpness: Normal (30%) (0 - 100% = range)
Coring: 75% (Less noise)
Setup Level: 0%
Master PED: 0%
NR:Off
Also do the following:
Gain = 0
Shutter = 1/50 (1/48 NTSC)
Iris/Fstop = As required (Low = less DOF)
WB = Manual (While Balance correctly - very important - can use compensation)
LENS:
OIS: Off (except if handheld)
Focus: Manual (Use Marks / ZR1000 for exact racking focus - works very nice - clicks)
ND: Use ND filters to control Shutter/Gain/Iris for outside.
Outside vistas and long shots = Iris Small (High F-stop) = long DOF
Use Wide Angle converter for establishing shots.
Light well to compensate for DOF (1/3inch CCD) and you don't need a Mini35, etc
I also use a Light meter which is very important. I meter, determine my ND, Fstop and set it on the camera. This way you have very little problems.
I have a sequence in which I do all the above, because if you mix them up, your results are different.
Sample
Sample
I didn't have time to take nice samples. I hope this helps:
1. Standard
2. Preset
3. Presets
60.f2.pct
59.f1.pct
I tend to Crush the blacks in post as to not loose colour information in recording, however the sometimes I switch between a basic preset and cinematic preset so I can make choices accordingly in shoot :)
Dumb question, do all the 0% values mean all the way left on a -/+ slider or halfway between - and +, im not sure if all the sliders are 0 to 100 or -50 to 50. Thanks
