Chance White
Anyone found a solution/workflow for FCP?
For now I'm just going to convert to DVCPRO 23.976 then reconnect for export.
Is d90 ntsc then? But it isn't 24p embedded in 60i? - pure 24p, right? So there might be chance 25p 1440x1080 dowrez'd to 720 could work with 1280x720 so lines wouldn't be a problem, right??
>talking serious stuff here. You can surely use cs3 or 4
>if you have them but to play is one thing, working is another
>you say grading and color correcting. Big words. But i doubt you
>know what that means. Or what postproduction is.
>stick around you might learn something.
Whoh, ease up hard-guy!
This forum is open to all levels, from noob to industry leaders. If using ae for color grading is an upgrade from fcp for the new user, then so be it. Use your vast experience and knowledge to help teach rather than bashing someone upside the head with your ego stick.
This driving me crazy. I can play files in VirtualDub without putting a strain on the CPU. Playing them in WMV/MPC/BSPlayer or similar is using 100% CPU.
I think I have tried every MJPEG codec there is now, looking for the one I had. Most of them puts less strain on the CPU (none as low as playing in VirtualDub though), but then the gamma (or something) is all wrong so I cant use them. See attached pictures to see what i mean with difference in gamma. The darker one is from using an efficient codec. The most efficient one I tried was Morgan MJPEG codec.
I don't know how to proceed anymore. I just want it to work the way it was.
I'm having issues with FCP - on one of my macs FCP can preview fine when clips are added to the sequence. On my other I get the "unrendered" message. They have identical sequence settings. Does anyone know if we need specific codecs installed to get FCP to play fair?
