Alright... this one took a moment and it's nothing special. A few notes before you check the links:
--Letus Ultimate and Zeiss C/Y 135/2.8, 50/1.4
--HPX with adjusted CineD and CineV Files
--Captured through an AJA to ProRes (HQ) 4:2:2
--Shot through a window with "Tint" on it already, so these could have been even sharper. Food for thought
Stills --
www.kholi.net/CarAndGreenDVCProHD.tga
www.kholi.net/CarAndGreenProRes.tga
www.kholi.net/LeavesDVCproHD.tga
www.kholi.net/LeavesProRes.tga
www.kholi.net/OfficeDVCproHD.tga
www.kholi.net/OfficeProRes.tga
www.kholi.net/TreeDVCproHD.tga
www.kholi.net/TreeProRes.tga
Video --
www.kholi.net/Comparison1H264.mov -- Small File
www.kholi.net/ComparisonH264Large.mov -- Larger File
The LEFT side is DVCproHD and the RIGHT side is ProRes (HQ)
The differences are a bit more prevalent in the "raw" footage.
How is DVCproHD? DVCproHD is quite a fine codec in comparison to a Full Raster and efficient codec. Keep in mind that ProRes (HQ) is damned near indiscernible when dealing with Uncompressed Comparisons. It's quite nice.
Is the resolution jump needed? Needed? That's a strong word. Welcomed? I'll take every little bit I can get within reason. Which means I'll take this as well. Mostly because I use a 35mm Adapter ritually. Those who don't? I wouldn't bother.
Is the image fidelity far off? This is my personal favorite. Check out the difference in noise patterns and image clarity all around. ProRes is awesome. Even tough the HPX is kicking out some gained-up images (I will still stand by the HPX being noisier than the 200) the ProRes Codec brings it back to a place that I actually like as much as the 200A. It's smooth, less macro-blocky -- which isn't a term-- and you should go and throw the footage or stills through some grading and see how it holds up. DVCproHD starts showing banding and brings out the blocks VERY swiftly. ProRes? Just rocks. It also seems that DVCproHD washes colors a bit. ProRes retains a fair amount of color detail which is sweet. Throw all that in with the very slight boost in resolved detail and the overall package is a lot sweeter.
Is it practical? Hell no. And, if I had to be tethered to a deck just to get this image quality I better have the budget. AKA two people to sit at a computer, a really computing rig that's extremely mobile, lotsof SDI cable to stay out of my way. Or...
Convergent Design's XDR and NanoFlash units.
What's that mean? I have a strange feeling that Convergent Design's mobile CF reader could be a nice thing to have around. The Sony Codec being used is Full Raster 4:2:2 MPEG-2 and you've got the choice between i-Frame @ 160mbps or LongGOP at 100mbps. Records sound through the HD-SDI port as well. So, it's an alternative that I want to test out here really soon. Seems like the mileage comes in post when you want to grade a bit heavier and you want the extra resolution.
The real weak link? 1/3" CCD Technology... I hope this is the last CCD Based Camera that Panasonic releases.
Thoughts welcomed.
Stills --
Video --
Thoughts welcomed.
