filmer1001
All this thead was for, was to show g35 footage and show what it can do. Also to encourage people to shoot in optimal situations to really show all the adapters strengths and weaknesses. That's all
Hello 35mm techy adapter world.
I just purchased a HPX170 with the CINEMEK G35 adapter. I come from the film world and I have to say that my results with the adapter are GREAT. No moving parts, no batteries (unlike Letus, Redrock, SGPRO and Brevis). This system is hands down the best out there in my opinion. I have been reading other message boards that talk about adapters and what they think works and what doesn't. But I have discovered that no one talks about LIGHTING. How are you suppose to judge the quality of an adapter and try and compare it to FILM if you are not going to Light Properly??? There is no reason to use the adapter unless you are going to shoot in good light, or any other system. If you have great light your stuff is going to look good no matter what. The G35 is just another tool to help achieve a better look. I keep seeing all these postings on the "Bokeh" and which adapter achieves the best one but who cares about the "Bokeh if the light is shi*? the "Bokeh" cant make bad lit footage look nice. Also, good "Bokeh" relies heavily on LENS choice. If everyone goes out there and shoots great lit stuff people will clearly see that the G35 Adapter is the best choice hands down.
So unless you want to show up on set and have your $2 motor inside of your $1,200 adapter break and piss off the whole set, save yourself the time and get the G35. Easy setup, great feel, amazing manufacturing and an all around great system.
TEST footage. all my settings and codecs are messed up so it kind of strobes in some parts in HD, but the SD version is clean.
http://vimeo.com/1959100
Thanks,
Dana
www.danamorrisphoto.com
of course if you have a deal on the RED it is cheaper. But the going rate for a full red package not including lenses is around $1200 a day. Regardless, if you have the money the RED the better choice than any adapter.
Now, perhaps in your eyes, like everyone on this board, don't know squat about lighting, but to double the wattage on lighting can in many cases offset any budgetary benefits of a low cost adaptor.
www.timnaylor.com
Tim,
I will be out in NYC on a gig second week of november. we can try and link up there and you can give it a try. i will try and post some frame grabs for you later. adios
dana
You have tons of options for adapters. Some will work for some people in every situation. Some won't. Your options are to either buy the one that will work in the most amount of situations you care about or purchase a different unit that will cover the remaining situations.
Thanks!
Hey, from where do you know my name, from my webpage? I just saw that you are from the Netherlands, right?Danke Michael ;-)
