filmer1001
Hello 35mm techy adapter world.
I just purchased a HPX170 with the CINEMEK G35 adapter. I come from the film world and I have to say that my results with the adapter are GREAT. No moving parts, no batteries (unlike Letus, Redrock, SGPRO and Brevis). This system is hands down the best out there in my opinion. I have been reading other message boards that talk about adapters and what they think works and what doesn't. But I have discovered that no one talks about LIGHTING. How are you suppose to judge the quality of an adapter and try and compare it to FILM if you are not going to Light Properly??? There is no reason to use the adapter unless you are going to shoot in good light, or any other system. If you have great light your stuff is going to look good no matter what. The G35 is just another tool to help achieve a better look. I keep seeing all these postings on the "Bokeh" and which adapter achieves the best one but who cares about the "Bokeh if the light is shi*? the "Bokeh" cant make bad lit footage look nice. Also, good "Bokeh" relies heavily on LENS choice. If everyone goes out there and shoots great lit stuff people will clearly see that the G35 Adapter is the best choice hands down.
So unless you want to show up on set and have your $2 motor inside of your $1,200 adapter break and piss off the whole set, save yourself the time and get the G35. Easy setup, great feel, amazing manufacturing and an all around great system.
TEST footage. all my settings and codecs are messed up so it kind of strobes in some parts in HD, but the SD version is clean.
http://vimeo.com/1959100
Thanks,
Dana
www.danamorrisphoto.com
Thanks,
Dana
