It's inevitable. In a few years, the rolling shutter issue will most likely be moot with all cameras.
The limitations of the DVCPRO HD footage produced by the HVX, and now the 170, are manageable; if I had some JelloVision on my footage I would had not be able to use it.
If you were doing this again, and using the 170, would you use the HD-SDI out if you could?
ProfD:
I believe the movie you are talking about that used the DVX100 uncompressed out was NOVEMBER with Courtney Cox.
Blackout, or maybe HVX is normally soft? real film is not very sharp in the movies too!
The reason that rolling shutter doesn't affect the Red shooters as much as EX-1/EX-3 shooters is not entirely due to weight differences (I can swing a Red back and forth just as easily as the EX and see skew) but because Red has tweaked their sensors to get a faster read-rate from them. A Red has less skew coming off the sensor than the EX cameras. Skew is there, but it's not as much.
QUOTE]
There was only a 10% improvement with their software upgrade.
The isssue has never been tweaking. If this was the case, it would of been done on all CMOS based cameras. I've had an EX1 right next to the RED ONE several times, their CMOS artifacts looking very close. A while back, Jim Aurthurs had examples online of the RED ONE skew artifacts.
The problem is with the current technology of CMOS sensors, but this all might change soon. RED's new offerings is going to shake things up.
Very true, but there is detail in film. This is all about resolution.
The first thing to do with ALL of these cameras is to shut off sharpness. We all know its adding artificial enhancement to make the image look sharp.
The problem is many of these cameras do not look good without artificial enhancement.
I love it when people talk about how film is soft. It's not SOFT. By any means! People are so used to watching Standard Definition they don't realize how sharp film really is.
You need every bit of resolution you can get out of these dinky little cameras, especially with adapters.
I hear you Kholi.
It's going to get REALLY interesting in the next couple years.
I'm hearing Scarlet is going to be better than we thought. Let's hope the price stays close to as predicted.
If it stays in the $3k price range, we'll all be tossing one of these in our tool bags.
