Matthew Bennett
I rented the k20D for the weekend -
HERE's SOME FOOTAGE that I liked: My first experiences were quite horrific, but then I shot some footage/frame bursts that I really liked. It's pretty passable!
h264 480p:
http://www.qmediasolutions.com/guest/CAMERA_TESTS/Bennett_k20D_test_h264_480p.mov
The camera gives you 1500x1000 sequential JPEGS at best quality, in a 115 frame burst of 21 fps.
So if you convert that to 24p, you get five seconds of slightly sped up 24p.
What you do is set to burst mode, depress shutter and then it films for five seconds. And THEN it takes a whopping, painful 20 SECONDS! to write all that buffered data to the card. There's no way around this, I'm using the fastest available sdhc card. The camera locks you out of everything while writing to the card.
The 4GB card only holds 4.5 mins at this data-rate.
I did a couple of tests yesterday and was expecting gloriously gorgeously downsampled JPEGS...(cause of that test we all saw..) and was surprised to see some weird chromatic red/green fringing issues, slight stair stepping on fine diagonals
But I went out again this morning with the 18-205 pentax lens I rented with the camera, shot some telephoto stuff in Chinatown in Toronto, took those JPEGS into AE and made a nice, graded, 720p pro-res, and ... It's actually looking pretty good now.
Hard to find all the weird artifacts I found yesterday... I don't know what I was doing differently yesterday.
Anyway, I wouldn't buy this camera, but its actually really nice to be in COMPLETE control of ISO, shutter and aperture during a DSLR movie capture! What a joy.
It's like having a five second shot preview edition of the second generation Nilkon or Canon.
I definitely recommend renting for a weekend if you're a DSLR-movie fanatic like me.
I will post some results...
Also the camera has pretty much the same jello as the D90 if you're moving about... so no love there...
Oh and also it does this weird thing on every other shot, which is to just randomly switch the white balance around...
ON TO THE PICS:
Here's one of the first shots I took:, this is a JPEG directly from the group of sequential JPEGS the burst mode generated: They are usually about 500KB to 580KB each in size.
You can imagine my horror when I cracked this open .... Now from further tests I realize its the result of the sharpening and contrast being cranked up, (I now use a soft portrait-y mode..)
h264 480p:
ON TO THE PICS:
