I have Hi8-quality images..
40 views and no guesses, huh?
Okay, let me ask this instead. How can I get Final Cut Express to actually recognize the camera plugged in so I can see a live preview of the shot so I can compare the two?
I don't mind spilling out the cash for a Firestore if the problem is simply just an SD vs HD thing, but I need to KNOW that it will look good before I do that.
That's no excuse either way, i've shot with a DVX and the quality is 1,000 times better than what i'm seeing now.
it looks seriously compressed for some reason. Is that how it looks when you look through the viewfinder?
Nope, looks fine in the viewfinder..
Did you accidentally put it into an HD timeline and then take a screenshot?
No, iMovie automatically started it out as a DV project once the camera was connected. (I wanted to do it in Final Cut but I can't get it to recognize the camera)
Guys, this is a 720x480 frame scaled to over 1440 pixels across. Of course it's going to look like crap.
Live preview, unscaled. http://sporadicmovement.com/misc/scc.png
You can capture directly to FCP in most flavors of DVCProHD.
Have you tried that using a live feed via firewire?
I have the firewire plugged in. Camera switched to "P2". In FCP it has the Device Control set as "Non Controllable Device" and the Capture/Input matches the REC format on the HVX. When I hit "Capture Now" the capture window pops up for 1 second and then disappears.
If that won't work, are there any alternatives I can try for free? I JUST need to test it this once to make sure I don't have a severe problem.
In the log and capture window I saw the live feed pop up once before. But now it says "Preview Disabled" and I can't get it to show anything.
