For those concerned about "backing up" the AVCHD media in the field for fear of losing your work, someone mentioned earlier that the SafePhoto II might be an option. Well, we did it and it works. While we didn't do AVCHD tranfer from an SD card we did do HDV from a Compact Flash and did ~5 gigs in about 15mins. While the transfer rate is a little slooooow in our opinion it is a nice companion. In the field we see mounting the unit on our side with a belt pack, dropping the production card in the unit and start the transfer, then let it click away the gigabits while we are shooting on another card then change cards as often as needed.
Now for those thinking otherwise, we WON'T format and reuse the card in the field because of our past experiences on messing up data through operator errors and also SD card failures, but instead we will KEEP the inexpensive card and take it to the studio for editing along with the back up hard drive data. The idea here is (assuming we go HMC150) we will use the SD card for production and transfer to editing - while retaining the HDD data offloaded onto DVD data discs or other HDD's for archival or back up purposes (as the case may be) until the project is completed or filed in the case of archival customer or internal requirements.
Now here is even more sweetness, the unit is simple to use and battery powered PLUS it comes with two charging options for the Li-ion battery, USB cord and AC. Slick. Don't know how long the battery lasts but the 160 gb's means we can store up to about 10 of our Compact Flash cards (if full of course) which is a real plus!
