Clint Nitkiewiz Hernandez
I may have mentioned everything in the title already, but,
I shot in 1080pa mode on the hvx200, transfer the files to my system, etc.
I setup my new project with an easy setup option, hd, 23.98 fps, dvcpro hd - 10pA24.
I then do the log and capture option. and there, under the import preferences, I click the little box that appears "remove advanced pulldown and duplicate frames", which will do my 2:3:3:2 pulldown automatically correct.
Here is where things get tricky, and unclear, and interlaced for me.
So I drag my footage to a new sequence, and it automatically asks me to change the sequence settings to match the clip. Why would it do this? I thought easy setup creates default sequences that are 1920x1080 with 23.976 fps with the codec I specified. Also I though my clip is 1920x1080 @ 23.976 anyways.
So for the purpose of trying to figure this out, I created 2 test sequences, where I said yes on one instance, and no on another. Here are the results in the sequence settings.
Yes; 1280 x 1080 HD 16:9, 29.97 - every 5 frames in the timeline I get interlacing
No; 1280 x 1080 16:9, 23.98, every 4 frames in the timeline i get interlacing
So what should I pick, I get interlaced footage either way, what is the proper method to do this? Thanks.
Also what is a good way to flip footage without having to re-render, Im sure this flipping question has been talked about but I could not find it anywhere.
