And you watched the whole seven minutes?
Reminds of the line in Annie Hall:
"Not only was the food bad, but the portions were small."
LOL, Classic
Low light, as in "can you make sucky footage in too-dark conditions"? That kind of goes against everything I stand for.But the next footage I post will have proper exposure and tons of black/dark areas... no gain though, I'm an anti-gain fanatic...
I found this dont mind the PooTube quality
http://www.youtube.com/watch?v=xRWOyhAGoR0
still waiting on vimeo footage since I wont be able to test until sunday! If I ahave a
Old Dual core 2.0ghz with 4GB Ram PowerPC mac with FCP 6.0.1 I should be all good for log and capture from what I have read right? or do I need that AVC-Intra plug-in for FCP like someone else brought up worked for them? worst case senario I I pay for Voltaic converter....
VIMEO PLEASE!!!!!!
Added: August 13, 2008 (Less info)
Footage shot at the WEVA Expo 2008 on the unreleased Panasonic AG-HMC150 AVCCAM. Camera will be available Sept 2008.
Please not that in the streaming video there is some noise and artifacting but this was NOT in the raw footage. Converting a 1920x1080 resolution video clip recorded at 24Mbps down to a 1.5Mbps video will result in some degradation. Please enjoy this sample clip.
I tried opening files listed below in Vegas 8.0b with the following library (beta from Sony's website): Name: m2tsplug.dll Folder: C:\Program Files\Sony\Vegas Pro 8.0\FileIO Plug-Ins\m2tsplug Format: Sony M2TS Version: Version 1.0 (Build 1236) Company: Sony Creative Software Inc.Vegas still seems to have problems with the 60p footage I tried. Still, at least there seems to be some hope.
. . . Will using pro res be anymore time consuming than digitizing tape? Thanks again to Barry
Sorry I am running a PowerPC mac and from what I have read even if I upgrade to final Cut 6.0 I am still screwed because I dont run intel's??? same with the Voltaic converter sofware.... is this true do I need to upgrade to a intel based mac......sigh....sigh....
I'm running voltaic on a ppc g5 quad. i was able to transcode the clips but I think the voltaic conversion may introduce artifacting that may not have been there.
Same.Hey, Barry... can you confirm that the remote-control protocol/connection is the same as the DVX/HVX?
720/60 makes for an ideal downconversion to 480/60i.When shooting with this camera/codec 720/60p does it yield good 480/60i footage after downconversion? Or should I shoot in a different formate?
Or just buy editing software that doesn't force you to convert. :engel017:that sucks the whole point of converting isn't to introduce more problems it just to convert into usable format and not loose quality argh this is frustrating I may have to hold on on this cam if I can't get the quality out of it you know. Or buy the cam and a ne 24" imac dual 3.06ghz intels......just a thought you only live once right.:beer:
"Can't comment on the former part of your querry but if no one else responds I can get an editor to provide the workflow they came up with and the conclusions they found if you would like."
Yes that would be great. I don't edit but most of the editors I work with use final cut and mostly work with tape. If I get the HMC 150 I want to make sure in advance they can handle the footage and not hose them.
