Hi Guys,
I did do a search but was inundated with many threads that consisted of people being told that it 1080p really is progressive frames even though it's within an interlaced stream. I failed to find exactly what I was looking for, but apologise in advance if my search skills were lacking.
I've shot almost exclusively in 720p since I bought my HVX and have only just taken on a job in which I can utilise the 1080i/25p capabilities of the camera. It looks great, however, I am concerned about how I should be outputting the footage once I have edited it. The job is a cinema commercial, so the delivery format is 1920x1080 lossless quicktime at 24 or 25 progressive frames (in a non-interlaced stream. I need to get to true 1080p).
My question, however, is this. When I render out from after effects should I be rendering out with the lower field first interlacing to preserve the original quality and then performing a de-interlace with compressor? Or will leaving the 'field render off' not affect the quality of the final render and dutifully combine the fields into a true and complete progressive frame?
I am just concerned that leaving field render off is only taking one field of each frame and duplicating it. I have compared the results and the lower field first does seem to resolve more detail. However de-interlacing in compressor using the best settings visibly degrades the quality.
I would be eternally grateful if somebody could help me with some information on how best to merge these two identical fields.
Thanks in advance. . .
