Ok, I've finally gotten a Final Cut Pro system of my own and I love their implementation of a P2 workflow compared to Avid's. It works so much smoother, and is easier to deal with. I really like the open timeline as well for mixing formats. I've been using my system a lot to sort out compatibility issues my coworker has with stuff shot in different resolutions/frame rates because he can't seem to understand that you can't mix as easily with an Avid system, which is what we have at the office. I digress....
Here's what I'm doing:
I've got a bunch of shots that are mostly shot in 720p60 on the HVX200. I've also got a handful of shots that I've mixed in that were shot at 720p24 (native) overcranked to 60fps. I'm editing on a 17in. MacBook Pro with the hi-res screen. I have my sequence setup to use the DVCPRO HD 720p60 sequence preset. When I do a full screen preview, I am very unhappy with what I see. I'm seeing individual pixels around certain areas of the image. For example, the edges of a window frame in the shot are pixelated, while the rest of the frame looks great. I thought it was possibly interlacing creeping in there somehow, but I'm thinking it has to do with the 960x720 resolution of the 720p footage from the HVX200. It's definitely not interlaced. I tried to keep everything shot in 720p24, but my coworker can't stop messing with the cameras after I get them setup for a project, and now I've got to get in the habit of checking them before I press record so that I keep as much as possible in he same format.
This pixel issue bothers me more when I attempt to burn a DVD of the footage because even on an SD display monitor from DVD, I notice the jagginess of certain areas of the image. I will also add that I notice it on both the 720p24 and 720p60 sections of the sequence. As for DVD authoring workflow, I send the sequence to Compressor and encode it using the DVD Best Quality 90 min. preset. I make sure "progressive" is turned on, as well as check to make sure it it setup to burn a 16x9 DVD. I've played this DVD on both my HDTV thru an upconverting DVD player as well as a SD TV set thru a regular DVD player. Both have noticeable jaggies around car window frames, an other similar areas. As I mentioned earlier, I also get the jaggies on my HD computer monitor when previewed in full screen mode.
Any idea what (if anything) I'm doing wrong? Is this just a deficiency in the HVX200 compared to higher end cameras that shoot full raster 1920x1080p resolution files?
Any help is appreciated!
Thanks!
Thanks!
