Use daylight setting and white balance on someting white on the Apple screen
Why not leave the monitor off or even better, cut out a green screen matte and composite the FCP project into the monitor in post. You might end up with better results than dealing with a monitor...
No need to cut out anything if the person doesn´t get between camera and ACD...This would be the best way to go, but I've never shot green screen before, or composited it, so it might be a but risky this time. Where would I get the material to cut out?
Green screen and compositing? All for a simple interview shot?
Don' complicate things unnecessarily.
Simply white balance the camera for the actual light you'll be using:
Zoom in on a white card or sheet of paper, set your white balance, then shoot your subject. The monitor will give off it's natural color temperature in the shot. It doesn't need to be compensated for.
Just a simple corner pinning...
You change colortemperature with the button on the front of the HVX, if on "preset" well you´ll get the presets, if on a or b, push the button for manual WB...
PS I don´t know the ACDs, but a lot of monitors offer different colortemperature settings...
I wasn't aware you can set it on 2 WB settings at the same time? I know how to set WB, but where is the daylight setting? (HVX noob here).
