Really? People wouldn't have switched from VGA to DVI (same video spec as HDMI) if it wasn't pixel accurate. 4:4:4 is definitely an option in the spec at up to 16 bit color in v1.3, but that is typically only used in computers and video games. Most video (and recording devices) is 4:2:2, so I bet you are right. Do you think it will add pulldown to allow for viewable/recordable 24p? It is possible to output 24p (some bluray players do it), but few devices accept it and I'm doubting this will have it.HDMI never carries 4:4:4, that's not part of the spec (as far as I know).
Back in the edit suite, I simply plugged the USB cable into the camcorder and computer, and the SDHC card popped up on my desktop. I was using a Final Cut Pro system, so it required a lengthy transcode process to transfer all my AVCHD footage into the ProRes codec. It wasn't exactly the connect-and-edit simplicity it should be, but that's a problem for the editing software companies to figure out.
To judge image quality, I connected the camcorder directly to an HD video projector via HDMI. I was astounded by the image clarity and detail. The AVCHD implementation by Panasonic was superb. Even notoriously difficult-to-compress scenes, such as blank beige walls, showed no banding in the image. Wide shots of trees blowing in the wind had no discernible artifacting around the leaves. The AG-HMC70 delivered clear, vibrant and naturally-saturated images right out of the box.
Conclusion
Panasonic's AG-HMC70 is one of the most affordable shoulder-mounted, full-sized camcorders on the market. I had some concerns with its electronic menus, but its image quality and audio capabilities are top-shelf. If you're in a market where size does matter, it's definitely worth a look.
We don't know a lot about the HMC150 yet. What we do know is:What are the main differences in features between the HMC150 and the HPX170 (other than P2 capability)?
Will the HMC150 have an image flip for 35 adapters?
Nice find Bob, haven't seen that review anywhere (link?), but was exactly what I was hoping to see. I've only seen one other review on the 70 that wasn't very positive, but didn't give much detail and was more harsh on the body design itself (which is understandable, it def has a specific market that is small compared to the DVX/HVX).
