SonicStates
Just ordered the El Cheapo!
Thanks for the lowdown!! Yet again DVX User members rocking!
A real brace should have a baseplate the interchanges with your tripod head, for quick on/quick off switchovers in a fast-paced shooting situation.
Adding the fluid head to this brace probably solves a number of problems, particularly the up/down tilt and the quick change from brace to tripod (however, now you're into the cost of an additional fluid head).
In the final analysis, I think the brace has its proper uses, but they are very specific and somewhat limited.
.... even whilst breathing.
It's a simple quick release/slider:
http://www.bhphotovideo.com/c/product/554151-REG/Bogen_Manfrotto_357_357_Pro_Quick_Release.html
You have to buy two of them, making the whole thing more expensive than the El Cheapo itself.
Mine is attached directly to the El Cheapo - using none of the El Cheapo risers. Also, it should be noted that this arrangement only really allows viewing with the LCD. The EVF is out of reach. Put a hoodman H400 on there and you have a neat setup.
The 357 has 4 countersunk screw holes. It would be possible to drill 4 holes in the El Cheapo plastic mount and, using hardware mount the 357 directly to the El Cheapo, eliminating the big 1/4-20 knob. I haven't done this yet.
You need one bottom plate for your El Cheapo and one for your fluid head. It leaves you with an extra top plate.
I have pictures but I am not permitted to post pix here for some reason.
If not, the tap you need is an english 1/4-20. Is the thru hole drilled to the right size for tapping it?
