Make sure that you have sturdy sticks. As soon as you flip that 2X converter in, even the slightest camera movement is amplified dramatically.
Having said that, I just used mine on the this last job, and it really does work well if you setup properly.
-Brad
Do you think that the Miller solo 1505 (carbon fiber) with Sachtler Video 15 SB are sturdy enough or do I need a tripod of the type Sachtler Eng 2 CF which has a mid-spreader ??? I would like to have the Miller since it is more portable and the maximum height is much larger (aldo the last will probably not increase the sturdiness when using an extender).
I used the 15SB with the 500 and it is the perfect size.
That being said I've been looking at the Cartoni Deltas recently.
Yes someone with first hand experience :2vrolijk_08: Is the video 15SB also the perfect size when using the 500 in combination with a matbox, external lcd or is it too light and you need a bigger fluid head? Which tripod do you use? Which lens do you have and what is your experience with the extender at least if you have one.
Why HPX over REDOne? If you have the cash, get the Red. Just shot with it...love it.
you get an hpx500 fully working system for 20000 including lens - you only start with a RED body for 17500 - price is a huge factor - you are really talking 35000 to 40000 to shoot with RED when all is said and done
I got into my Red for less than 25K, with batteries, cards, lenses, monitoring and support.
Well its pretty close to 25K...I
Canon FD mount (from Muse Electronics) $450
Starter set of Canon FD primes (used):
20mm f2.8 $200
35 f2 $175
50mm f1.2 $250
85 f1.8 $200
135 f2 $300
