Jason Ramsey
Admin
I'm not sure... Barry might know or someone else. Otherwise, I'll ask tomorrow. I would *think* so....
later,
Jason
later,
Jason
They basically did. :thumbsup:I wish Panasonic added a Frame rate dial on the camera body.
That's pretty much a good summation. You missed the best little unexpected update: it can now play back pretty much all clips regardless of what format they were shot in!Summary changes in HPX170 compared to the HVX200 :
improved light sensitivity (0.5 stop)
increased S/N
less smear
HD/SD- SDI
20 in stead of 12 frame rates
flip frame
6-pins FW
last clip delete button
PAL/NTSC switchable
3 types of focus assist, wave form + vectorscope (can be switched off on demand)
framerate change out of menu structure
joystick type of control of play functions like in the DVX (and not 90 degrees rotated)
lens 72 mm (instead of 82 mm of the HVX)
no DV tape deck (which makes the cam lighter and smaller)
extra ND filter
anti-theft provision
correct me if I am wrong or missed something
When you sum it up like this it is a huge change !!!
Yes it's much improved. The battery now mounts vertically (like the DVX used to), which protects it against the increased leverage that the HVX200's horizontal mounting exposed it to.I wonder if they also improved the battery mounting system (the first HVX200s suffered from breaking "plastic" tabs in the battery bay). Maybe they made them now from metal ?????
The 150 is basically the identical same hardware. Not all the same features (no HD-SDI, no variable frame rates) but most of the same features. Same imaging, same picture, same lens, same waveform and vectorscope, everything is basically the same. The major difference is the recording media and format (AVC-HD on SD cards, vs. DVCPRO-HD on P2 cards).nice move panasonic ! totally tapeless and more sensitive than the HVX200 at a lower price. I wonder how that AVCHD model will fare compared to this one.
Don't know. It wasn't on any external button, so maybe it's something that's set in the menus. These cameras don't have menus enabled yet, they're still prototypes. I'll try to remember to ask tomorrow.Any word on if this will be on the HMC150 as well?
there is also a toggle switch that changes the focus ring on the cam to an iris ring. The ring is still free spinning with no hard stops, but can now be used for Iris or Focus.
Since the HVX is now including a P2 card, I wonder if this cam will have one in the box as well. That would be awesome!
HMC150 has HDMI. HPX170 has HD-SDI.I thought it had an HDMI out? Is that incorrect?
That would indeed be excellent. Don't know, as we're probably five months away from shipping and they didn't even announce a firm price yet. But I would be surprised if it didn't.Since the HVX is now including a P2 card, I wonder if this cam will have one in the box as well. That would be awesome!
Jan did mention in an interview that they're going to be bringing back the 8GB cards.
If that's the case I woudln't be surprised if one was included with the cam.
I can't see them throwing in a 16 or 32GB card in as standard though.
Then again - who knows.
Tthe HVX200 now comes with a free 16GB card, right?
