ZephyrStar
I kinda hope that this will drive the price of the 100b down a little more...I'd still like to have one as a starter cam. That'd just give me a little more $ to put into the actual production.
does it have 82mm thread lens. uses the same lens as the hvx200?
No. The HVX200A is the same as the HVX200, but the HPX170 uses a 72mm lens. It's smaller and lighter, with a wider focal length range (3.9mm-51mm, vs. the HVX's 4.2mm-55mm). Still a Leica Dicomar, everything looks basically very similar, probably the same basic design etc., but it is physically smaller.does it have 82mm thread lens. uses the same lens as the hvx200?
I wish Panasonic added a Frame rate dial on the camera body.
I think Sony did this with the EX3.
The 170 goes back to the vertical battery mounting system the DVX uses, not the horizontal of the HVX.
You know, when I first saw it I thought the horizontal system was really odd - but now I've gotten used to it. I think that's one of the things I'll miss if I move over to a 170 when it's released. Seems much faster to pop the battery off horizontally, ergonomically it just feels better.
Don't know if this was mentioned or not, but Jan mentioned today that the HPX170 has an lcd flip function for 35 adapter users.
Does indeed have additional framerates (20 in all). The focus assist (one of the three focus assist functions) can now remain on instead of cutting off after a few seconds.
She mentioned that NTSC/PAL switchable is still up for debate, but it sounds like it may be an upgrade option at the very least... but nothing confirmed nor denied on that feature.
don't know if the 200a will have the lcd flip or not, and the focus assist that stays on rather than automatically cutting off... But, a lot of little features like this mentioned about the 170 that really look like they will help fill out the camera.
later,
Jason
