OIS is for more or less still shots where there's no panning etc.
Interesting feedback. Not what I expected. I wouldn't use it when panning either, but I don't see a point on using OIS for a static still shot shot?
I felt using it on a bouncy car ride is a good example of when you might consider it. Kinda like skiing.
Are you saying other then the known "jump" on tripod pans, the image is degraded? I hadn't noticed, but I've only used it on really bumpy stuff that wasn't for paying gigs, so I might not have looked close enough.
As mentioned, I agree you are better doing it in post if your editor has the option. SpeedEDIT has a decent IS app as well. I haven't used AVID's.
And yeh, shoot as wide as possible to minimize shake.
Goes to show, opinions differ so always take a sampling and don't listem to me!![]()
That's odd. My impression was that OIS removes the small bumps/shakes from handheld footage. So on a stablized system, you would not want it (tripod/dolly/crane/tripod pans/etc.)
However, whenever shooting handheld, you would. SO - for a car scene with it mounted, yes, your cam would be locked down... but all the vibrations and bumps from the road would seem to actually make this footage very similiar to handheld footage with the little vibrations/bumps.
I would definitely have it on. There are times, like making a u-turn that you might get a frame jump looking artifact, but the rest of the footage would be improved.
This is just my take on it though. Others might have differing opinions.
I use it while ski shooting and it helps about 10-20% in my opinion.
OIS is not meant to be used when the camera is on a tripod or stabilizing system regardless of the shot type. There is no need to optically stabilize an image that is already stabilized because as said before it can and most likely will cause "jumps" in the motion
I think you're missing the point here slightly, Slinkii.
Hey Chip, I was wondering how your shoot went? Did you end up using OIS?
