mackfilm
So I swore to myself that this would never happen to my dvx100b when i took it from the box. But it did...I was holding it by the bottom checking out a shot with a friend, and my other friend was kicking his soccer ball around and it smashed into my dvx...pushed it from my hands...it spun twice in the air before crashing into the cement.
THE BAD:
-The LCD is busted, bent, and broken off
-Viewfinder wont come on (even when I push it in that little knob inside the LCD control panel
-Not sure if any internal damage has occured because I cant see an image
THE GOOD:
-Body is relatively unscathed
-it turns on fine and makes the usual sounds.
-the tape compartment and play heads spin as normal when I open it.
-Lens is not cracked, perfectly fine---however I'm not sure if anything happened inside
Im crossing my fingers that the 3ccd censors are fine.
I have a 1 year warrannty on this...and it is still valid. Will Panasonic cover this? How much do you think it may cost? I had a hand strap on my hand, so I was using their safety devices.
Here are some pics:
THE BAD:
THE GOOD:
Here are some pics:
