I have yet to edit any footage shot with the HV20 but I want to be prepared, for when I do. Reverse telecine seems to be the core process and I do have several formulas and applications ready to do this.
Right now I am having a hard time understanding how you can properly convert the HV20 29.97 to 24p without artifacts.
If one of the problems with deinterlacing HV20 footage is if the first frame you start from is not a "key" frame, and instead one of the GOP frames, won't that effect the reverse telecine process?
To further illustrate my point. If I hit record and capture 10 seconds of footage then stop and record another 23 seconds and so on for a full tape, Then capture all the footage into FCP with "capture now", won't the sequence of the Key frames constantly be changing?
In my mind that should result with a improper cadence if Key and GOP frames. So that when you apply reverse telecine to an hour of footage in theory some of the footage will be deinterlaced poorly and some perfectly.
Does that make sense?
I just want to make sure I understand the underlying concept at work
