i have the budget just enough for a Sachtler DV6 SB setup. do you guys think i better buy the Sachtler (i'm sure i won't regret) or the libec is good enough for me to play with for years and just save the money up for other gears? i'm having a tough decision here...
btw my setup is an HVX with Letus EX, RR follow focus and IKAN monitor (planning to get a mattbox)
Ahh Jon, I think you sort of need those "rubber nubbins" so you can securely attach the floor spreader!!!!!at First my LS55 didnt fit for some reason in the case supply with the feet on. But now it does.... the only thing I did was take the little rubber stops off the spikes on the bottom and whala it fit. I have no Idea if that was the reason, but ever since I did that, It has fit perfectly and snug. I have no Idea that that small of a difference would do it. But I have since lost those rubber nubbins, so I cant se if they where the culprit.
Jon
I finally got a chance to use my LS38 on a shoot - wow what a difference from the manfrotto combo i had (501 head). Finally able to start and stop a pan w/o a jerk. it's the little things that make me happy![]()
I wish that there was a way to get everyone who thinks the 501 is a real tripod head to read your post!
Enjoy it!
Dan
well, when buying the 501, i was looking for the cheapest "fluid" head available, and that was the 501.. i'm sure a lot of people buying it are in the same boat. I also was buying only the head since i already had a tripod so that was another decision. If, however, you've got 600-700 to spend on tripod/head combo, the L38 is great!
