According to the Panasonic website, ( http://panasonic.co.jp/pavc/global/videocamera/hd/global/products/hdc-sd9/specifications.html ) it's 3 x 520k chips, so I'd assume 3x960x540. Given it's 1/6" chips, I wouldn't expect any greater.Is the sensor 1920×1080 native or does it use pixel-shifting or some other resolution-enhancing technique?
correct me if im wrong, but isnt this camera without headphone and mic jacks? i would love to have this camera, but the lack of audio control makes it useless to me
For Professionals, you're right, it doesn't sound good at all.Hmm... Like the HVX200, but with sensors only a quarter the size. Doesn't sound very good at all.
I suspect it has more to do with size than cost, and that is true for all manufacturers. If you want a very small camera, it will have small chips, and it will therefore be compromised with respect to resolution and/or sensitivity. To say nothing of diffraction problems severely limiting usable aperture range. As has been said before - this is fundamentally a consumer camera, nothing wrong with that, but don't expect it be other than it is.so Panasonic should be taking appropriate measures and begin developing AVCHD cameras that produce higher image quality, set at a higher price of course, to accomodate that part of the market.
Camera manufacturers are already making consumer cameras with larger chips -- dSLRs and dSLR-like cameras. Most models in the former category use chips that are close to to the size of a 35-mm motion picture aperture, whereas the latter category uses chips about a half inch. At least two companies are basing models on Sony's IMX017CQE CMOS chip: Casio's Exilim Pro EX-F1 is a still camera that does video, while Samsung's SC-HMX20C is a video camera that also does stills! In other words, the line between digicam and camcorder is becoming increasingly blurred, particularly with the elimination of tape drives. Nothing is preventing the development of a dSLR-sized chip with similar (or better) specs. True the ergonomics differ between still and video cam, but that would seem relatively easy to sort out.No doubt newer Panasonic cameras will come along with bigger chips, but at a certain point doesn't it make sense for them to be AVC-Intra, rather than AVC-HD? At a certain (mid) point in the market, being switchable to either format may make a lot of sense.
If that is true, I can only say I'm surprised.While AVC-Intra would be a better choice for professionals, the added cost of the technology -- for the camera circuitry .......... and the necessarily more robust editing systems (which possibly could be obviated with cheap coprocessors like the Cell) -- would seem to make it unlikely for an HVX-level camcorder.
Gee, I hope that Panasonic doesn't implement 50-Mbps-only AVC-Intra on an HVX-level camcorder. Maybe I'm mistaken, but it's 4:2:0 and 8-bit, which doesn't offer any advantage except twice the recording time -- and with greater P2 capacities (32 GB is a reality, and 64 GB is probably less than a year away), that should be less of an issue than it was. No, if it's going to go through the trouble of implementing AVC-Intra, Panasonic should do 100-Mbps. Hell, I'd like to see 200-Mbps for 4:4:4 encoding.What I can see happening for an HVX-level camcorder is AVC-Intra, but only the 50Mbs version - partly for fair technical reasons, partly for marketing. That's fair enough, but AVC-HD AS WELL may make sense.
But did you see either of them in other than good lighting? That's one of the main things that distinguishes consumer cameras and their small chips from more pro cameras.I saw this thing at CES, it was pretty cool. The Canon was pretty sweet too.........They both looked great.
Partly mistaken. It is 4:2:0, but it's still 10-bit.Maybe I'm mistaken, but it's 4:2:0 and 8-bit
Thanks, Barry, for the correction. Better than 8-bit, but still only 4:2:0, and not full 1,920 x 1,080. At 100 Mbps, however, it would have the same data rate as DVCProHD, but a greater color space and a 50% greater horizontal spatial resolution (yeah, I know, pixel count, not necessarily significantly better real-world resolved detail).Partly mistaken. It is 4:2:0, but it's still 10-bit.
