mvb
DVXuser Sponsor
Any benchmarks on how long it takes to process clips?
720p add/remove pulldown is about as fast as a file copy, the noise reduction and image rotate can take up to 4 minutes per minute (on a 2G Core 2 Duo).
Is a new clip created to preserve the original clip, or is this destructive?
hi mvb, love raylight, but iam wondering how much noise is it really taking off when something is lit, shot properly without gain
mvb, can you answer one technical question:
Would there be any perceptive difference in resolution and motion rendering with native 1080p25 vs 1080p25 in a 50i stream edited in a 50i timeline?
Should be the same unless you apply speed changes or use dissolves or other transitions. 25P material in a 50i timeline will acquire interlacing and a different look when you
use dissolves or apply other motion effects.
Thanks for the education, mvb. To conclude this, if I was, for example, setting for a 50i sequence in FCP and selected "no fields", would this improve the motion rendering in said effects?
Thanks again for your time!
Looking to purchase the mxfx when its mac available (and pal compliant for 1080p and 25p)
If you change a 50i sequence to "no fields" then its not 50i anymore, it's 25p.
Not to sound like an ass or anything but I looked at the first picture comparison you posted and I can't see much of a difference. The only thing I notice is a loss of detail on the concrete in the "noise-reduction" version. It kind of just looks like the result you'd get by lowering the detail in camera.
Is there something I'm missing? Is there an area that perhaps I'm not seeing properly?
On a few files they do help with the noise but at the expense of detail. The tend to "smear" (for the lack of a better word) fine detail...
The answer is in bigger and better sensors, of course.... The only answer is hardware noise reduction, i.e., better sensors.
