HV20 HDMI-out pre/post DSP?
vj_jasper
please, i would love to know.. can the HV20 do 4:2:2 1920 by 1080 uncompressed output via the HDMI output?
some people say it can, others say it cannot, there is not much discussion in-between.
the nay-sayers believe that the signal does not go direct from sensor to HDMI output, but rather goes the DSP chip aswell, and then through the HDMI output, and contend that if this is true, then surely the signal is down-converted from 1920 to 1440, compressed to HDV info rates, 4:2:0 colour space, ready for recording to tape.
if the signal does go through the DSP chip before streaming out through HDMI, then surely it does indeed get compressed? unless of course, there is another smaller chip that does the downconversion just before the info-tape process, but if so, then what is the main DSP chip doing?
maybe the signal does not go through the DSP chip before the HDMI output. hope so :)
thanks all in advance for some great heapful info :-)
by the way, Cineform is bringing out an HDMI recorder! direct to 32 gig inexpensive Compact Flash cards, and it can capture 4:2:2, and save it in the proprietary (and well-respected) Cineform 10 bit 4:2:2 codec.. so, quality footage capture, without the need for overly large, cumbersome files of 340 gigs per hour.
When you use HDMI out with a capture card like black magic you can record pre-compression video which will be 1920x1080 with 4:2:2 color spacing.
It definitely goes through the DSP. It definitely doesn't go through the HDV compression. As to whether it's 1440 or 1920, or whether it's 4:2:2 or 4:2:0, that I don't know.
According to Blackmagic HDMI uses 4:2:2 video and since the native resolution of hv20's CMOS is 1920x1080 it should capture 1920x1080 with 4:2:2 color spacing.
Wow. I wonder what the price is on that Cineform. CF storage would be cheap.
The HV20 with a Cineform recorder with a Letus adpater would be a pretty mean setup....
Yes, BUT: just because the HDMI standard is 4:2:2, that doesn't mean the HV20 outputs 4:2:2! It may, or it may not. Maybe it outputs 4:2:0 embedded in a 4:2:2 signal.
For example, all the HD-SDI camcorders under $10,000 (except the EX1) that output an HD-SDI signal, do so at 8 bits. Even though the HD-SDI standard is 10 bits, these cams generate an 8-bit signal, and 'pad' the last two bits with zeroes to fill out the sequence.
So it's not a sure thing that the HV20's outputting 4:2:2. It might be, but it would need to be tested to be sure.
Thanks for the information Barry. I wonder if anyone here has a blackmagic intensity card. I am sure the Blackmagic intensity is worth the money since it is only $249 but I am really curious if it is worth paying $2000 for a portable solution.
in a word, yes it would be.
er, thats four words, anyhoo.. it would be very worthwhile for EX1 owners because instead of filming at 4:2:0, it could go direct to CF, and transfer 4:2:2 at true 10 bit, and be recorded at Cineform's very well respected, intraframe, 10 bit 4:2:2 codec.
a very portable solution for the EX1.
i just would like to know if it would be doing the HV20 any favours..
if the HV20 goes through the DSP and then to the HDMI port, it would almost certainly be travelling out as 1440?
however, hopefully all is not lost. if the HDV compression has not been applied before output to HDMI, then capturing into the Cineform or into an Intensity card would save a lot of colour and contrast info, resulting in less noise, less artefacts, better filmic blacks, and richer detail.
quite possibly a better lowlight capacity too.
as regards storage, it is not a very viable solution at this point imho.. $300 for a 32 gig Compact Flash card. it is a portable high-quality-capture-solution.
there is a solution for storage for the EX1, a drive that has optical disks that store around 23 gigs, and are about 12 dollars each.. shelf-life at least fifty years. the optical disks themselves look very nifty :)
Here are the specs per the CineForm website (http://www.cineform.com/products/CineFormRecorder.htm). But... they say on the site that there isn't an estimated delivery date... By them time it's available, who knows how many options there will be!
(Preliminary) CineForm HDMI Record Module Feature Spec
Physical Interfaces:
HDMI A/V Input
HDMI A/V Output
USB: interface for attachment to record bay
Audio: 2x RCA input (maybe)
Headphone output - 3mm stereo mini
Dimensions: Approx 5"W x 3"D x 1.5"H
Record Format:
CineForm AVI or MOV (user selectable)
Spatial Resolution: 1280x720 or 1920x1080
Chroma: YUV 4:2:2
Precision: 10-bit
Frame Rates: 23.976p, 24p, 25p, 30p, 50p, 50i, 59.94i, 59.94p
Record Media:
Compact Flash
External laptop drive through USB interface
Approximate Record Times for 10-bit 1080p24
- 32 GB CF: ~ 40 minutes
- 160 GB 5400 rpm Laptop Drive: ~3 hours
UDF drive format
Note: Can record both to CF and through USB simultaneously for data redundancy
Record Features:
Auto-detect camera modes (?)
Two Quality Modes: “SP” and “LP”
Inverse Telecine processing
Deinterlacing
Time code recording (Spec TBD)
Image Flip (for lens adapters)
Variable-length pre-record. Keeps 5-15 seconds of video recording in advance of hitting the RECORD button.
LAN-C interface for START / STOP camera control
Record Monitoring:
HDMI pass through
Recording preview on LCD screen
Player Features:
Ordered playlist queue
HDMI A/V playout
Preview on color LCD screen
User Interface:
LCD panel similar to iPod LCD panel (touch sensitive?)
5-button context-sensitive menu interface
3 modes: SETUP, RECORD, PLAYER
Power:
Mounted battery - still TBD
Price: Sub $2000
thanks JD, that's some cool info.
i wonder if the LCD screen on the cineform capturezone (my own title for it) would be sufficient to pull focus, if using a Brevis35 converter on an HV20 or even an EX1.
have you seen the optical disk storage system that is or will be soon available? very cool.
so, specs are great.. i wonder if canons website has the proper specs for the HV20 HDMI output.. what exactly is the information that streams from that port?
Not for the EX1. The Cineform unit is an HDMI recorder, not an HD-SDI recorder. Although if you got an HDSDI->HDMI converter, then you could use it (presumably).
Not necessarily. Just because the HV20's recording format is 1440, that doesn't mean the internal processing is done at 1440! The HVX200 does all internal processing at 1920, and then downrezzes to record. The HV20 might do the same thing. If so, the 1920->1440 might happen at the recording stage, and the HDMI output might still be 1920.
There's almost no question that it does. If any picture effects, color effects, transition effects, or -- well, ANYTHING other than a raw image is displayed via HDMI, then that means it's going through the DSP. I don't have my HV20 anymore, but if someone else wants to verify that then you'll know for sure. I'm 99.5% sure.
ah yes, the EX1 does need an SDI-HDMI converter to work with the cineform hdmi recorder. (presumably.. unless cineform adds an SDI input too).
actually, word on the street is that the models after Ex1 in the XDcam range are going to be recording 4:2:2 colour in 2008.
i would really like to see some Hv20 frame grabs from footage captured at a high quality direct to disk utilising an Intensity.
reports have said that there is much less noise than when recorded as HDV signal to tape.
Hmmm...Hasn't this thing been in "development" for some time now? I for one would LOVE to get my hands on one but...I am having flashbacks...Nintendo CD anyone? Exactly...:laugh:
