Lenilenapi
Carbonite Member
Well i don't take those f numbers too seriously. My measurements were made on a waveform. I'm not sure why you feel the need to so exact about this particular measurement though.
what would be curious to see is not just on the HVX200, but other cameras as well
Canon XH A1 + UV Filter
Wow, those of you have have Z settings of around 80ish surprise me- For full frame I can zoom out to Z72 (Although I keep it at Z74 to be safe.) and For academy frame I keep it at Z78 (Which I'm liking the Academy framing more - especially if I have to use different unmatched lenses, as it tends to even out the light response.) Something else that I have noticed is that I can zoom out a little more if I have the Letus mounted snorkel up, then if it is down- I have no idea why this is....
So in short I'm using: (Snorkel up)
Full Frame:
Z74
MF50
Academy Frame:
Z78
MF50
UPDATE:
I figured out why I needed to be zoomed at Z80 to see no vignetting. Because my GG was not centered. Letus instruction sheet makes it sound real easy: they say that if you are using their braket, and some support rails, you should be lined up right for the get go. But it is far from the truth. In fact I was very far off, image was too far down and way too far right. As a result I had to zoom in a lot to be "inside" the GG.
well, mine wasn't dead center either, which is also the reason i need to zoom in further than i may like to in some circumstances
I think the vignetting" also depends on the lighting environment.
anyone tried their adapter in an ambient lit (ceiling lights) room at night?
you can get a very spot lit centre - not just vignetting on the left/right, but quite a balanced even drop off all around (top+bottom+side 2 side).
a lot more camera zooming is required to crop this compared to the regular vignetting seen on one side (as gg is a little off to one side, as i read - typically the left side) during daylight/bet lit environments.
