D dolph2000 Well-known member Nov 30, 2007 #1 does the chrosziels 4x4 mattebox from hvx200 fits the canon les on hpx? (with rods thats fit the hpx.
D dolby Well-known member Dec 1, 2007 #2 Using the Fuji lens, it fits very well using the cavision rails.
D dolph2000 Well-known member Dec 4, 2007 #3 thanks but does it fits the canon lens. I can't find the specifics of the width of the canon lens
mikkowilson Steadi-Guru Dec 4, 2007 #4 Which Canon Lens? (For example) all 3 of these Canon lenses work with the HPX500 (and every other 2/3" camera): Info on these and more Canon lenses here: http://www.canon.com/bctv/products/index.html - Mikko
D dolph2000 Well-known member Dec 4, 2007 #5 KJ16x7.7B-IRSD HDgc 16x 2/3" ENG High Definition Lens with 2x Extender, Manual Focus, Servo Zoom and Iris http://www.bhphotovideo.com/bnh/controller/home?O=ProductDetail&A=showItemLargeImage&Q=&sku=489934
mikkowilson Steadi-Guru Dec 5, 2007 #6 Specs here: http://www.canon.com/bctv/products/pdf/kj16ex7.7b_irse.pdf Lens diamier is 85mm, so a little larger than the HVX's 82mm - will probably work just fine, but you'd need someone with the mattebox to measure the hole to be sure. - Mikko
D dolby Well-known member Dec 5, 2007 #7 The I.D. of the stepdown rind that comes in the HVX matte bax kit is 91mm. Hope that helps. dolby
D dolph2000 Well-known member Dec 5, 2007 #8 that helps for sure, thanks guys. I know not to buy a new one when getting this canon lens
