This is really an after effects question which I posted to that forum. But I thought I also might catch people working with HVX200 footage.
Which is best for compositing HVX200 960x720 1.33 footage in After Effects? Square or 1.33 pixel aspect ratio workspace?
The final output is for D1 SD but also want to preserve for future HD resolution i.e. 1280 x960 square resolution.
Here is the step by step example comparison:
1.33
1. Import 960x720 1.33 footage (leave interpret footage as is)
2. Compify clip, creating a 960x720 1.33 comp
3. Composite and work in this comp. Use Pixel Toggle aspect ratio correction to temporarily display for square viewing without compromising footage.
[Pro's: 1.33 toggled space keeps the footage completely untouched until final output. Cons: displays with slight artifacts on edges stair-casing etc. This may make it difficult to cut a matte.]
Square:
2. Create a new comp 1280x720 Square.
3. Drop in footage in new square comp.
[Pro's: you can see your footage clean with no artifacts. Con's: you have compromised your footage. You will then need to stretch again to D1 ]
A composite package like Fusion apparently doesn't have any temporary display artifacting while in the PAR correction.
Does anyone have any recommendations for the optimal work flow?
1.33
Square:
