We shot a project on the HVX200 16:9 720p for a 4:3 SD full screen final result (not letter-boxed).
The footage consists of clips with these properties:
960x720 (1.33)
DVCpro HD 720p60
23.976 fps
In FCP we need to set up two sequences 16:9 & 4:3
The 16:9 settings as follows:
Frame size: 960x720 (HD (960x720) (16:9)
Pixel Aspect Ratio: (HD 960x720) anamorphic unchecked
Compressor DVCpro HD 720p60
23.98
Can anyone recommend optimal 4:3 settings for a FCP workflow?
We want to preserve the highest res for editorial and compositing. We know this can easily be conformed in after effects. But we would like to Edit in FCP preserve the 720 height and crop the width without affecting the clips at all. 960 x720 is 1.33 so at a square res it would be 1280x720. A square 4:3 comp would be 960x720 but when we set up 960x720 square the clips auto letterbox. ou can remove attributes but then it squashes. You can resize the clip in motion window which seems to work but causes loss. And down the rabbit hole we go. Does anyone know the standard way to do this?
960x720 (1.33)
DVCpro HD 720p60
23.976 fps
23.98
