when i drop the File into Vegas t keeps crashing vegas. it saysd an Exception has occured and it kills, the Program........
i wonder why?
i wonder why?
TimurCivan said:thats the one that crashes.....![]()
Yes, but you'll have to get it by email, so drop a line to support@dvfilm.comdusterdoo said:Marcus - Could you supply a link for the 202-8 version...THanks
mvb said:We've reproduced the error here, which is goodBut until there's a permanent fix, if you use Vegas 7.0d, revert back to Raylight 202-8 or earlier version,
if you have it. Users of Premiere or Vegas 6 are unaffected.
Marcus,
Quick question:
I have Canon's XH-A1 and would like to know if it is possible to use Raylight as an Intermediate Codec using the camera native 24F, 30F and/or 60i by capturing directly in Vegas 7 or Premiere Pro 2 as 1440x1080 24F. Also, would like to know since I will be doing some green screen work in the near future, how does it handle the color space (Chroma) - IE is it 4:2:2 like Cineform or 4:2:0 like native Canon HDV.
I am between deciding to go with either Cineform Neo HDV or Raylight, and would also like to know aprox. how many streams at the lowest level of proxy quality can I load with simple cuts on an Opteron Dual Core 2.6 with 1 Gig of ram (possibly upgrading to 2 later) 120gb system drive and 160gb dedicated video scratch drive. Whew! Sorry for asking so much.
Thanks so much in advance.
Tony S.
Does the ability to shoot in 720p/24pN always been a feature of the HVX200
The other would be does the same apply to the P2 CARD firmware for the 16Gig card? When will the 32Gig come out and what will be the cost. Thanks again....
Cameras manufactured in May 2007 or later came from the factory already able to use 16GB cards. Any manufactured prior to that date would need to be upgraded. You can check if yours needs it or not; go to the MCR menu and check for "system software" and if it's version 4.05 or 4.06, you don't need an update.The other would be does the same apply to the P2 CARD firmware for the 16Gig card? When will the 32Gig come out and what will be the cost. Thanks again....
