Hello,
Hope all is well. I have a feature film, that i have to eventually output to Sony HDCAM. The 90 minute film was shot on the HVX200 on an AVID XPress PC computer. The footage was stored and edited on eSata drives. The only output i have is from the computer via a firewire.
My outputted project must have a stereo mix on channels 1 and 2 and music effects only on 3 and 4. I can't rent a Sony HDCAM deck, because the inputs are only analog in (with the exception of the HDW-1800, but the firewire input is HDV only). I have outputted an HDV version of the film, but would like to have the DVCPRO HD quality on Sony HDCAM.
The only way i can see not to loose quality is to rent a Panasonic AJ HD1200A deck which has a firewire input. I would then output on my computer to the AJ HD 1200A deck. Once the tape is outputted transfer the DVCPRO HD tape to Sony HDCAM at a duplication house. Then i would have to dub the tape again with audio insert only creating a separate stereo (Music and Effects only) on channels 3 and 4 on the HDCAM master.
Basically what is the cheapest and easiest way to output to Sony HDCAM from a DVCPro hd project that can only be outputted via firewire. So far this looks to run me at least $800 with the DVCPro HD rental and the HDCAM transfer. Anyone have any cheaper suggestions (without losing quality). Also can Panasonic DVCPro HD tapes record 90 minutes of HD material? Some of the tape specs look strange to me and are not clear. Do i have to record on two separate panasonic tapes? Any recommendations on a cheap output to Sony HDCAM.
thanx,
Omar
thanx,
Omar
