Printing HD to HV20?
pinboxer
Does anybody know how to " Print to Video " in FCP to an HV20.
I've never had this problem with regular DV.
I recorded my footage. Imported into FCP, Edited and now I am trying to Print it back to the camera but the camera keeps telling me to check the HDV/DV input.
I've tryed everything I can think of. And I can't understand how the footage goes into the computer but won't go back to the camera.
Any help is appreciated.
Thnx
Choose the HDV 1080i Easy Setup. This will make sure the device control is set to the proper protocol. (Sony HDV)
Also, be sure that the HV20 is set to HDV for VCR mode.
Do a "Print to Video" at which point you will have to wait for the program to render new GOP's, and then it should automatically record to tape according to your settings. (Bars, black leader, title slate etc.)
Be sure to check the little box for "automatically start recording" at the bottom of the PtV window.
Of course, this is all assuming you're working in a native HDV timeline in FCP 5 or later.
Print to video
Print to video
In FCP 5.1 or FCP 6.0 the way to do this is the following:
1. Easy Setup for Canon will be: HDV 1080i FireWire Basic
2. If you dont get the indication in FCP that its "conforming to HDV" than your project needs to be reset to the easy setup listed above. Conforming will take several min. even longer if the project is longer. There is a work around to this which once you get it to print at all I can give you.
3. This camera WILL NOT go into record mode with FW connected until it sees an incoming signal 1st. That means you need to ignore the message in fcp to put the device into record then click OK. That wont work.
You have to do it in reverse click OK then once the camera gets a signal it will go into record, ....black will appear on the LCD of the camera THEN you can put the device into record mode.
Whether an update in fcp or a firmware update in canon will come along to make this work normally is hard to say.
