How to get you're new 16g P2 to work
RyanKR
The following link gives the instructions on how to update your cameras firmware. People who are experiencing problems such as the "incompatible card" error, should follow these steps by panasonic. This is what I had to do in order to make my 16GB P2 card readable.
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/hvx200/hvx200verup_e.pdf
Once you read though a bit, and format your SD card either via computer or camera, page 2 tells you to download the driver software. Below is the direct link, just hit accept.
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft_agree_e.htm
unzip the file and then drag the PRIVATE folder into the formatted SD card, and then just follow the instructions on page 3 of the first link.
Hmm, I just received mine today and performed the firmware upgrade. Camera says it is 4.06 yet the card still doesn't work. I have no pmcia slot for the card to test it out even...
Any ideas or do I need to send it back?
Ok so this is a kick to the balls....I have an old SD card that Ive been using for my HVX to store scenefiles and such. I go to install the firmware to the card...I format it and it says its too big for the SD card.
The card is 16mb and the update is 17.5mb....this sucks!!
What other methods were there to update the firmware without the SD card?
Might want to keep it a little more professional.
In any case, the firmware update instructions indicate that a minimum 64 MB SD card is required.
You can get these for nearly free at CompUSA.
Walmart sells a 1 GB SD card for $10.00
This is the only way to update firmware on the cam.
How do you miss the big label stuck to the card box telling you that you'll probably have to upgrade the firmware in your camera?
Because I; like many others, were just so excited that the card actually came after waiting months, opened the box and put it in my camera, to then realize the error and immediatley go on this forum and search the error. to then come accross people syaing to send it back. I posted this so those people will also see this thread and hopefully not send back a working card. :)
I´m with you on this, the firmware update with 16GB cards and the HVX just isn´t obvious and instead of "smart" comments this thread should get the sticky status (that is, if everything on the update procedure is stated correctly...)
:thumbsup:
:thumbsup:
thank you, im on my iphone right now but when i get home i will fix the errors
Well I have a cam serial G7TCxxxxx that will recognize one 16gb card but not the other!
firmware ver is 4.06-00-0.00
what's going on???
I'm sorry, hopefully someone can help you with that, because I don't know what's going on there.
Can someone please tell me how to delete a thread or change a thread title. I need to either change the title of this or create a new one......
what's going on???
Try formatting your other card. Otherwise, It may need to be returned and replaced.
Andrew Hoffman
Senior Operations Manager
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858
301-790-0103
Fax: 301-790-0173
andrewh@spec-comm.com
www.spec-comm.com
Please visit our new online store at ( http://www.spec-comm.com/store ).
New products being added daily!
For everyone that is having problems with updating your firmware, we are performing firmware updates for $85 at our Authorized Service Center. Included with the $85 is a general checkout and a thorough cleaning of the camera.
To have this firmware update and cleaning performed, please click HERE.
If you need to have your HVX shipped, click HERE for shipping instructions.
Please let me know if there is anything else that we can help with.
Best regards,
Andrew Hoffman
800-359-1858
301-790-0103
Fax: 301-790-0173
www.spec-comm.com
What do you do to thouroughly clean the camera.
Listen people, if you haven't learned do the simple update yourself, you are really in for a rough time with the actual operation of this camera.
I notice you corrected the misspelled "they're" in the subject line of your actual post, so this isn't really directed at you, but since so many other people do this stuff all the time, please forgive me for the following:
English Teacher Mode: ON
Your = the possessive, as in "Your DP reel is great"
You're = a contraction on "you are", as in "You're a great guy"
-and-
There = a place, as in "Point the HVX over there"
Their = the possessive, as in "Their DP is great"
They're = a contraction of "they are", as in "They're great guys"
-and-
It's = a contraction of "it is", as in "It's a great camera"
Its = the possessive, as in "My HVX and its P2 cards are way cool"
To wit:
"As an HVX owner, you're probably as amazed as I am at how great your camera is. Its feature set is awesome, and with bigger P2 cards coming soon it's only getting better. As for all the other HVX owners out there, here's hoping they're enjoying their cameras as much as I am!"
English Teacher Mode: OFF
:happy:
brokenjack,
We completely detail the camera. It also includes treatment of oil absorbing materials such as the hand grip strap pad, VF Eye peice rubber and sun shade. If the focus ring and zoom ring is gritty, it will be another hour of labor ($85) to remove all of the contaminated grease, treat and rinse the plastic, and replace the grease with new.
You should also know that if you have your camera repaired or just get a cleaning, you get $10 off our long life battery. Please e-mail me for details.
Best regards,
Andrew Hoffman
800-359-1858
301-790-0103
Fax: 301-790-0173
www.spec-comm.com
Please visit our new online store at ( http://www.spec-comm.com/store ). New products being added daily!
I think I'm going to have to send the 16 gb p2 back. There's not even an option to format that card, it's grayed out in the menu.
-and-
-and-
To wit:
:happy:
THANKS!!! I'm actually getting better at this english thing, thanks to you :cheesy:
I hope I have not offended anyone else with my typo on the title, in which I can't figure out how to change/fix.
seriously is there any way for me to do so?
Yeah, I'm sorry to hear that. I don't know why its doing that. There might actually be something wrong with the card. Wait and see what a few others have to say before you send it back. at least you have one working card though :happy:
