jenningsp
CALL ON ALL HV20 OWNERS - TO TEST FOR DROPOUTS
there have been quite a few reports that the HV20 randomly drops out every now and then.
I myself have replaced my HV20 twice because of this issue. i tested with several different tape brands in both HD and standard versions... i used head cleaners and one HV20 actually started chewing tapes after 4 hours of use and two head cleanings....
what is a drop out?
it's when the video cuts out for a second or two.
usually this is because the heads on the camera need cleaning and a simple head cleaning tape will fix it.... but this seems to be an issue with the HV20 it's self.
i think this issue mightn't have been noticed on a large scale for a couple of reasons... the dropouts are so sporadic that people who use the camera only a little bit might never come across it... some people mightn't be aware what dropouts are or that it's a problem with the camera... people using the camera for short takes ( 2 min, 3 min, 30 sec) might have just been lucky and not come across it yet.
how do i test?
the easiest way i've found is - put your camera in front of your TV and record a full hour of tape - the constant movement and sound of television make a dropout easy to detect.
then import your footage onto your computer - make sure you've got 'create new clip on start/stop' selected - after you've imported your footage, if there is more that one file, then you've had a dropout.
you can got to the same time in the time code on your tape to check it really was a drop out and not something else...
report back with what brand tape you were using and how many drop outs, if any, occurred in an hour.
i've found -
JVC PRO HD - 7 or more an hour
SONY HD - at least 1 an hour
SONY Exc - at least 1 an hour
what is a drop out?
how do i test?
i've found -
