Gord.T
Still "Senior Member"
3.4 gigs is right on the money.
To generate some preview files do this:
But first, I like to copy the particles and meshes folder to a backup folder.
-Open up the project again in RF4.
The time slider should be highlighted in yellow showing that it is already rendered.
( If it is not yellow it's likely because the project was not saved after it was rendered.
You won't be able to generate the preview pics but dont worry about it. As long as the
particles and meshes were generated your okay. )
-Press the F12 key to open Export Central.
At the bottom of that you'll see 'Preview'- Image sequence.
Check that and choose what type of file to save as. You'll see a box appear when you check it.
-Dont simulate or reset.
-Instead hit the play button that's to the right of the reset button. The one that looks like a VCR play button.
While it is playing you should see the animations on the screen.
If so open the preview folder and the pictures should be getting saved.
-I'll try and send the C4D files tonight.
What screen size for the video do you want? I'll set up C4D for that size.
