KETCH ROSSI
The new AJA I/O HD makes it possible to shoot high quality 4:2:2 to a MacBook Pro using the new ProRes codec, (possibly without a RAID too) which is superior to DVCPRO HD. But if you'd even consider doing tethered shooting, I would step up to a G1 and get embedded HD SDI output, otherwise you will need an analog HD to HD SDI converter box because you won't get very long cable runs with analog component from the A1.
Yes Elton, I have already one in list at B&H, this was to be with the RED'S set up, but I still do not understand if it is better to spend the money tryng to up-rez the XH-A1 with the use of such a box or going directly as you suggested to the G1 insted.
This are the true differences that also interest me.
And also in one or the other the goal is to get the best out of the set up but at a cost that justifis the spending.
Thanks.
Ciao
KETCH ROSSI
