I know you're at a slight advantage already since you're shooting PAL
Not to hijack but can you elaborate on this???
Got it. Thanks! For a moment there I was thinking it had something to do with latitude.I think he means the slightly higher resolution of the PAL DV format compared to NTSC.
Hello
It's important to set the gamma setting to "normal"(on my cam at least), so the the over exposed areas blend nice into the rest. If you use "cine-like" the over exposed areas kinda like cuts from white edges over to color, which looks awful.
