Maybe I'm wrong, but if shooting 720 60P I think you are going to drop it into a 60P timeline for normal speed through most of the wedding. Than change the speed to 1/2 (or even less should look fairly smooth) when needed. I would use ramping when varying the speed for a smooth speed change.
My 2 cents. Why not shoot in 720 30P? Then you would have real solow mo (As much as true 1/2 speed) as well as having a quasi film look. Unless they absolutely have to have that lovely reality show look. Slow motion in camera as opposed to in the editing software are two different things.
This would also give you an extra stop over 60fps for the 99.99% of the footage that is not slow speed.
Good luck.
And what are you going to use to author the blu ray HD DVD?
Compressor will not create blu ray compliant encodes and there isn't any blu ray authoring on the Mac.
Blu ray on the PC support is, at best, spotty, and not all blu ray set tops are consistent with blu ray recordable discs.
You better be careful if your final output is a blu ray HD DVD.
Dude, forgive me if I sound a little sarcastic here, but where have you been for the past few months???
Which blu ray set top have you authored to? The reason I ask is that many blu ray set tops are not compatible with blu ray recordables.
And which blu ray burner are you using with Compressor 3 on what Mac? You indicated that you were using 5.1 which does NOT include Compressor 3. That is part of the FCS2 package.
If you are shooting in 720 60P you are already shooting at 60 fps and have no more speed increase available. If you are shooting at 720 30P you are shooting 30 progressive frames per second and can now overcrank by changing the frame rate in the scene file to 60fps. When you play it back in your 30 frame timeline it will be playing back at half speed just like film.
Also shooting at 30P will give you the film look in camera without having to fake it later in post. 720 60P just looks like "Deal or No Deal" style video. I hope this made sense.
http://www.mcetech.com/blu-ray/
This is the one I was thinking of getting soon...
clipgloss:
i like the workflow of authoring in DVDSPro and burning the image in Toast 8... but I am also curious which units you have tested Blu-Ray playback in? I use my PS3 primarily as a blu-ray player... love to hear some positive results..
