tverhaar
I'll ask forgiveness up front on two counts here - first, I searched and browsed for info on this topic but didn't find anything. Second, I may not have found anything because I am probably a little weak on understanding precisely what I am asking... so here goes ...
I know that the XH-A1 records HDV to tape but I also know (think) that with the jackpack on the XH-G1 you can send an uncompressed signal out via the HD-SDI jack. This implies (?) that the camera itself captures this uncompressed signal but just doesn't record it on board. Assuming I am correct on this, does it mean that one can capture a higher quality signal from the A1 either (or both) of these ways:
1) through a PCI card into a laptop, (via FireWire?) or
2) into the new AJA I/O box introduced at NAB (does this give me uncompressed or just the ProRes 422 output?)
My questions arise from this: I am planning on buying an XH-A1 but would really like the option of capture a signal in the 4:2:2 color space (ProRes 422 would be fine, I think). I could upgrade to the XH-G1 but for not much more I could get either the AJA unit or a laptop with a capture card (as I say this I actually am not sure there are capture cards for a MacBook Pro(?).
I will continue to research this but any help or enlightenment would be much appreciated.
Regards,
TVH
Regards,
TVH
